This procedure does not apply to VSP 8600 Series.About this task
Use this task to view Fragmented ICMP packet filtering details on a Management Instance.
- To enter User EXEC mode, log on to the switch.
                View Fragmented ICMP packet
                    filtering:
                        For IPv4: show mgmt ip icmp [clip | oob | vlan]
                        For IPv6: show mgmt ipv6 icmp [clip | oob | vlan] Note This command does not apply to XA1400 Series.
The following table defines parameters for the show mgmt ip icmp command.
| Variable | Value |
| clip | Displays the IPv4 or IPv6 ICMP information specific to the management CLIP. |
| oob | Displays the IPv4 or IPv6 ICMP information specific to the management OOB. |
| vlan | Displays the IPv4 or IPv6 ICMP information specific to the management VLAN. |
