Configuring ACE IP options
Configure ACE IP option entries to have the filter look for packets with an IP option specified.
- The ACL exists.
- The ACE exists.
Options field descriptions
Use the data in the following table to use the Options tab.
| Name | Description |
| AclId | Specifies the ACL ID. |
| AceId | Specifies the ACE ID. |
| Oper | Specifies the logical operator for the ACE IP options. Any is the only option. |
