Specify the number of challenges that you want the RADIUS SNMP server to send to authenticate a given session.
RADIUS SNMP field descriptions
Use the data in the following table to use the RADIUS SNMP tab.
| Name | Description |
| Enable | Enables or disables timer authentication on the server. The default is true. |
| AbortSessionTImer | Specifies the allowable time, in seconds, before aborting the RADIUS SNMP server session (30 to 65535). The default is 180. |
| ReAuthenticateTimer | Specifies the time, in seconds, between reauthentications of the RADIUS SNMP server (30 to 65535). The default is 180. |
| AcctEnable | Enables or disables the RADIUS SNMP session timer. |
| UserName | Specifies the user name for the RADIUS SNMP accounting. |
