| Feature | Product | Release introduced |
| Simple Network Management Protocol (SNMP) v1/2/3 (IPv4) | VSP 4450 Series | VSP 4000 4.0 |
| VSP 4900 Series | VOSS 8.1 | |
| VSP 7200 Series | VOSS 4.2.1 | |
| VSP 7400 Series | VOSS 8.0 | |
| VSP 8200 Series | VSP 8200 4.0 | |
| VSP 8400 Series | VOSS 4.2 | |
| VSP 8600 Series | VSP 8600 4.5 | |
| XA1400 Series | VOSS 8.0.50 | |
| SNMP (IPv6) | VSP 4450 Series | VOSS 4.1 |
| VSP 8200 Series | VOSS 4.1 | |
| VSP 8600 Series | VSP 8600 6.2 | |
| XA1400 Series | Not Supported |
You can use the Simple Network Management Protocol (SNMP) to remotely collect management data and configure devices.
An SNMP agent is a software process that monitors the UDP port 161 for SNMP messages. Each SNMP message sent to the agent contains a list of management objects to retrieve or modify.
