Modify VLAN port members to control access to the VLAN.
In the navigation tree, expand the following folders: .
Click VLANs.
Double-click the PortMembers number for the VLAN for which you want to modify port membership.
Click the port members you wish to add or remove.
Click Ok.
Click Apply.
The VLAN port membership is changed.
