Important
Product Notice: VSP 8600 Series supports Policy Based Routing (Redirect Next Hop) Per VRF as a demo feature. Do not use this feature in production environments.
- The access control entry (ACE) exists.
If you use the mirror action, ensure that you specify the mirroring destination: MLTs or ports.
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# filter acl ace action 901 1 permit monitor-dst-mlt 5
The following table defines parameters for the filter acl ace action command.
| Variable | Value |
| 1-2048 | Specifies the ACL ID from 1–2048 |
| 1-2000 | Specifies the ACE ID from 1–2000. |
| monitor-dst-mlt <1–512> | Configures mirroring to a destination MLT group. |
| monitor-dst-ports {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} | Configures mirroring to a destination port or ports. |
| {permit|deny} | Configures the action mode for security ACEs. The default value is permit. |
