Configure Endpoint Tracking globally on the switch.
- In Extreme Management Center or ExtremeCloud IQ - Site Engine, configure your third-party virtualization platform, and the RADIUS server used for Endpoint Tracking authentication. For information about configuring Extreme Management Center or ExtremeCloud IQ - Site Engine, see the Extreme Management Center or ExtremeCloud IQ - Site Engine documentation at https://www.extremenetworks.com/support/documentation/.
                    On the switch, add and configure the RADIUS server as configured in Extreme Management Center or ExtremeCloud IQ - Site Engine.
                    Create and enable Endpoint Tracking on interfaces.
Optionally, if the RADIUS outbound attributes do not include an I-SID value, configure an I-SID offset value, and globally enable I-SID offset for Endpoint Tracking. The I-SID offset value is used to calculate an I-SID value for a switched UNI if no I-SID value is provided by the RADIUS server. In that case, the I-SID value is calculated as follows: I-SID = VLAN ID + configured I-SID offset value.
After optionally configuring an I-SID offset value, enable Endpoint Tracking globally on the switch.
If you have previously enabled Endpoint Tracking globally and want to change the currently configured I-SID offset value, you must disable Endpoint Tracking globally, change the I-SID value, and then re-enable Endpoint Tracking globally.
Use the data in the following table to use the Globals tab.
| Name | Description |
| AutoIsidOffset | The I-SID offset value. The default is 15990000. |
| AutoIsidOffsetEnable | Enables or disables I-SID offset value globally on the switch. The default is disabled. |
| GlobalEnable | Enables or disables Endpoint Tracking globally on the switch. The default is disabled. |
| VisibilityEnable | Enables or disables visibility mode for Endpoint Tracking. The default is disabled. |
