Use the following procedure to create an IPsec security association. A security association (SA) is a group of algorithms and parameters used to encrypt and authenticate the flow of IP traffic in a particular direction. An SA contains the information IPsec needs to process an IP packet.
You cannot delete or modify a security association if the security association links to a policy. To modify a parameter in the security association or to delete the security association, you must first unlink the security association from a policy.
Create an IPsec security association named newsa:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ipsec security-association newsa
The following table defines parameters for the ipsec security-association command.
| Variable | Value |
| WORD<1–32> | Specifies the security association identifier. |
