Create a VRF Instance
Create a VRF instance to provide a virtual routing interface for a user.
For more information on route scaling, see VOSS Release Notes.
Create a VRF instance:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ip vrf vrfRED
Configure the maximum number of IPv4 routes and enable max-routes traps.
Switch:1(config)#ip vrf vrfRED max-routes 12000 Switch:1(config)#ip vrf vrfRED max-routes-trap enable
Enter Router Configuration mode and configure the routing protocol triggers for the VRF:
Switch:1(config)#router vrf vrfRED Switch:1(router-vrf)#ip bgp Switch:1(router-vrf)#ip ospf Switch:1(router-vrf)#ip rip
To Configure OSPFv3 instance for the VRF:
Switch:1(config)#router vrf vrfRED Switch:1(router-vrf)#ipv6 ospf
Exit to Global configuration mode:
Switch:1(router-vrf)#exit
Configure the maximum number of IPv6 routes and enable IPv6 max-routes traps.
Switch:1(config)#ip vrf vrfRED ipv6-max-routes 7700 Switch:1(config)#ip vrf vrfRED ipv6-max-routes-trap enable
Ensure that the instance is configured correctly:
Switch:1#show ip vrf vrfRED
                                               VRF INFORMATION
VRF       VLAN      ARP       RIP       OSPF      BGP      PIM      NBRv6    RIPng    OSPFv3   PIM6
COUNT     COUNT     COUNT     COUNT     COUNT     COUNT    COUNT    COUNT    COUNT    COUNT    COUNT
2         5         0         1         1         1        1        0        1        1        1
VRF                        VRF  VLAN   ARP                                NBRv6
NAME                       ID   COUNT  COUNT  RIP    OSPF   BGP    PIM    COUNT  RIPng  OSPFv3 PIM6   ACTIVE
vrfRED                     1    0      0      TRUE   TRUE  TRUE   TRUE    0      FALSE  FALSE  TRUE  TRUE
1 out of 2 Total Num of VRF Entries displayed.
The following table defines parameters for the ip vrf command.
| Variable | Value |
| Depending on your hardware platform: max-routes <max-routes> | Specifies the maximum number of IPv4 routes for the VRF. Depending on the hardware platform, the parameter range and default value can vary. Use the CLI Help to see the available range for the switch. For route scaling information, see VOSS Release Notes. |
| ipv6-max-routes <max-routes> | Specifies the maximum number of IPv6 routes for the VRF. Depending on the hardware platform, the parameter range and default value can vary. Use the CLI Help to see the available range for the switch. For route scaling information, see VOSS Release Notes. |
| max-routes-trap enable | Enables SNMP traps after the maximum number of IPv4 routes are reached. |
| ipv6-max-routes-trap enable | Enables SNMP trap generation based on the configured number of maximum IPv6 routes. The default is enabled. |
| name WORD<0-16> | Renames the VRF instance. |
| vrf-trap | Enables the device to send VRF-related traps. |
The following table defines parameters for the show ip vrf command.
| Variable | Value |
| max-routes [vrfids WORD<0-512>] [WORD <1–16>] | Displays the maximum number of routes for the specified VRFs.
| vrfids WORD<0-512> | Specifies a list of VRFs by VRF IDs. |
| WORD<1-16> | Specifies a VRF by name. |
