Clear DvR host entries (IPv4 remote host routes) on a Controller. The host entries are learned on the switch, either locally on its UNI port or dynamically from other nodes in the DvR domain.
You can clear DvR host entries only on a DvR Controller.
An error message displays if you attempt clearing of host entries on a DvR Leaf node.
Ensure that you enable DvR globally on the node.
In this example, you clear host entries for IP address 50.0.1.0 to clear host entries for IP addresses 50.0.1.2 and 50.0.1.3.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#clear dvr host-entries 50.0.1.0
Variable definitions
Use the data in the following table to use the clear dvr host-entries command.
| Variable | Value |
| ipv4 | Specifies the IP address (IPv4) of the DvR host entries to clear. |
| l2isid | Specifies the Layer 2 VSN I-SID of the DvR host entries to clear The range is 1 to 16777215. |
| l3isid | Specifies the Layer 3 VSN I-SID of the DvR host entries to clear. The range is 0 to 16777215. |
