This procedure only applies to the VSP 7400 Series.
Perform this procedure to view the SPBM Service Instance Identifier (I-SID) information. The SPBM B-MAC header includes an I-SID with a length of 24 bits. This I-SID can be used to identify and transmit any virtualized traffic in an encapsulated SPBM frame.
- Select SPBM Remote.
- Select the I-SID tab.
- Optional: Select the Filter button to filter the rows on basis of specific criteria.
I-SID Field Descriptions
Use data in the following table to use the I-SID tab.
| Name | Description |
| SysId | Indicates the system identifier. |
| Vlan | Indicates the B-VLAN where the remote I-SID is configured or discovered. |
| Isid | Indicates the remote IS-IS SPBM I-SID identifier. |
| NickName | Indicates the nickname of the node where the remote I-SID is configured or discovered. |
| HostName | Indicates the host name listed in the LSP, or the system name, if you do not configure the host name. |
| Type | Indicates the remote SPBM I-SID type. The values are discover or configure. |
