Use the Unicast Reverse Path Forwarding (uRPF) feature to reduce the problems that are caused by the introduction of malformed or forged (spoofed) IP source addresses into a network. When you enable uRPF, the switch performs a check to determine if the source IP address of the packet is verifiable. If the address is not verifiable, the system drops the packet.
- strict mode
- loose mode (exist-only mode)
- You must enable the urpf-mode boot flag.  - Note - When you try to configure uRPF on an interface, that is, enable or change the urpf operating mode with the urpf-mode boot flag disabled, a consistency check error message is displayed: Unicast Reverse Path Forwarding configuration is not supported when urpf-mode boot flag is disabled.
- You must log on to the VLAN Interface Configuration mode in CLI. Important You must assign a valid IP address to the selected port.
Switch:1> enable Switch:1# configure terminal Switch:1(config)# interface vlan 2Check whether the source IP address of the incoming packet exists in the FIB table:
Switch:1(config-if)# ip rvs-path-chk mode exist-onlyVerify the configuration on the VLAN:
Switch:1(config-if)# show interfaces vlan ip
                                                   Vlan Ip
VLAN VRF    IP            NET              BCASTADDR REASM   ADVERTISE DIRECTED  RPC     RPCMODE     RMON
ID   NAME   ADDRESS       MASK             FORMAT    MAXSIZE WHEN_DOWN BROADCAST
1050 Globa~ 192.0.2.9     255.255.255.0    ones      1500    disable   disable   disable exist-only  disable
1102 Globa~ 198.51.100.1  255.255.255.0    ones      1500    disable   disable   disable exist-only  disable
1133 iir3   192.0.2.10    255.255.255.0    ones      1500    disable   disable   disable exist-only  disable
1500 spboip 192.0.2.11    255.255.255.0    ones      1500    disable   disable   disable exist-only  disable
1590 spboip 198.51.100.2  255.255.255.0    ones      1500    disable   disable   disable exist-only  disable
4057 Globa~ 192.0.2.12    255.255.255.0    ones      1500    disable   disable   disable exist-only  disable
All 16 out of 16 Total Num of Vlan Ip Entries displayed
VLAN VRF
ID   NAME
1050 GlobalRouter
1102 GlobalRouter
1133 iir3
1500 spboip
1590 spboip
4057 GlobalRouter
Switch:1(config-if)# ipv6 rvs-path-chk mode exist-onlyVerify the configuration on the VLAN:
Switch:1(config-if)# show ipv6 interface vlan
                                             Vlan Ipv6 Interface
IFINDX VLAN PHYSICAL          ADMIN   OPER  TYPE  MTU  HOP REACHABLE   RETRANSMIT  MCAST    IPSEC    RPC      RPCMODE
INDX        ADDRESS           STATE   STATE            LMT TIME        TIME        STATUS
3170   1122 2c:f4:c5:dc:b4:89 enable  up    ETHER 1500 64  30000       1000        disable  disable  disable  existonly
3174   1126 2c:f4:c5:dc:b4:8b enable  up    ETHER 1500 64  30000       1000        disable  disable  disable  existonly
3185   1137 2c:f4:c5:dc:b4:90 enable  up    ETHER 1500 64  30000       1000        disable  disable  disable  existonly
                               Vlan Ipv6 Address
IPV6 ADDRESS                            VLAN-ID      TYPE    ORIGIN    STATUS
2001:db8:0:0:0:0:0:1                      V-1122       UNICAST MANUAL    PREFERRED
2001:db8:0:0:2ef4:c5ff:fedc:b489          V-1122       UNICAST LINKLAYER PREFERRED
2001:db8:0:0:0:0:0:1                      V-1126       UNICAST MANUAL    PREFERRED
2001:db8:0:0:2ef4:c5ff:fedc:b48b          V-1126       UNICAST LINKLAYER PREFERRED
2001:db8:0:0:0:0:0:1                      V-1137       UNICAST MANUAL    PREFERRED
2001:db8:0:0:2ef4:c5ff:fedc:b490          V-1137       UNICAST LINKLAYER PREFERRED
3 out of 4 Total Num of Interface Entries displayed.
6 out of 7 Total Num of Address Entries displayed.
The following table defines parameters for the ip rvs-path-chk mode and ipv6 rvs-path-chk mode commands.
| Variable | Value |
| mode{strict|exist-only} | Specifies the mode for Unicast Reverse Path Forwarding (uRPF). In strict mode, uRPF checks whether the source IP address of the incoming packet exists in the FIB. If the incoming interface is not the best reverse path, the packet check fails and uRPF drops the packet. In exist-only mode, uRPF checks whether the source IP address of the incoming packet exists in the FIB. The packet is dropped only if the source address is not reachable via an interface on that router. |
