Use the following procedure to enable MLD snooping on the switch.
- In the navigation pane, expand the following folders: .
- Click IPv6 MLD.
- Click Snooping tab.
- Select a value, double-click the cell in SnoopEnable column, select True or False.
- Select a value, double-click the cell in SsmEnable column, select True or False.
- Click Apply.
Snooping field description
Use the data in the following table to use the Snooping tab.
| Field | Description |
| IfIndex | Specifies the interface on which you enabled MLD snooping. It specifies the port number if the interface is a brouter port or the VLAN number if the interface is a VLAN. |
| SnoopEnable | Indicates the status of MLD snooping on the specified interface:
| SsmEnable | Indicates the status of SSM on the specified interface:
