Enable jumbo frames to increase the size of Ethernet frames the chassis supports.
Switch:1> enable
Switch:1# configure terminal
Enable jumbo frames to 9600 bytes:
Switch:1#(config)# sys mtu 9600
The following table defines parameters for the sys mtu command.
| Variable | Value |
| <1522-9600> | Configures the frame size support for the data path. Possible sizes are 1522, 1950, or 9600 bytes. The default is 1950 bytes. |
