This configuration allows you to map the port with DHCPv6 Guard or RA Guard policy. You can view, create or delete the mappings.
Use this procedure to map a port to a RA Guard or DHCPv6 Guard policy, DHCPv6 Guard or RA Guard statistics.
- Click FHS.
- Click the Port Policy Mapping tab.
- Click Insert.
- Configure the parameters for the port policy mapping.
- Click Insert.
- Optional: Click Refresh to update the results.
Port Policy Mapping Field Descriptions
Use the data in the following table to use the Insert Port Policy Mapping dialog box.
| Name | Description |
| IfIndex | Specify the port. |
| DHCPv6GuardPolicyName | Enter an already-created DHCPv6 Guard policy name to map it with the port. |
| RAGuardPolicyName | Enter an already-created RA Guard policy name to map it with the port. |
| Dhcpv6gDeviceRole | Select server or client configuration. The default is server. |
| RagDeviceRole | Select host or router configuration. The default is router. |
Use this procedure to display port policy mapping information.
- Click FHS.
Use the data in the following table to use the Port Policy Mapping tab.
| IfIndex | Identifies the port. |
| Dhcpv6gDeviceRole | Specifies the DHCPv6 Guard device-role of the received port. If the device role is client and if it receives DHCPv6 reply then those packets should be dropped. |
| DHCPv6GuardPolicyName | Specifies the DHCPv6 Guard policy name associated with the port. |
| TotalDHCPv6PktRcv | Shows the total number of DHCPv6 packets received on the DHCPv6 Guard enabled interface. |
| TotalDHCPv6PktDropped | Shows the total number of DHCPv6 packets dropped due to DHCPv6 Guard filtering. |
| RagDeviceRole | Specifies the RA Guard device-role. |
| RAGuardPolicyName | Specifies the RA Guard policy name associated with the port. |
| TotalRAPktRcv | Shows the total number of RA packets received on the RA Guard enabled interface. |
| TotalRAPktDropped | Shows the total number of RA packets dropped due to RA Guard filtering. |
| NDInspection | Enables or disables Neighbor Discovery (ND) inspection. The default is disabled. |
| TotNdPktRcv | Shows the total number of ND packets received on the RA Guard enabled interface. |
| TotNdPktDropped | Shows the total number of ND packets dropped due to RA Guard filtering. |
| ClearDHCPGuardStats | Clears, if true, the DHCPv6 Guard statistics for the port. |
| ClearRAGuardStats | Clears, if true, the RA Guard statistics for the port. |
| ClearNDInspectStats | Clears, if true, the ND-inspection statistics for the port. |
Use this procedure to delete the created port policy mapping.
- Click FHS.
- Select a row from Port Policy Mapping to delete.
- Click Delete.
- Click Apply.
