Display information about BGP network configurations.
The following table defines parameters for the show ip bgp networks command.
| Variable | Value |
| <prefix/len> | Shows paths with this prefix. The prefix is the IP address and exact mask length (must be an integer value from 0–32). |
| vrf WORD<1–16> | Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
| vrfids WORD<0–512> | Specifies a range of VRFs by ID number (the ID ranges from 0–512). |
