Use the following procedure to set the trust factor associated with a port for DHCP Snooping. By default, the trust factor is set to untrusted.
For ports that are members of an MLT, DHCP Snooping must be configured using the MLT configuration mode.
You must enable DHCP Snooping globally.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitEthernet 1/2 Switch:1(config-if)#ip dhcp-snooping trusted
The following table defines parameters for the ip dhcp-snooping command.
| Variable | Value |
| <trusted|untrusted> | Specifies the trust factor of the port for DHCP Snooping. |
