Use ACE Ethernet VLAN ID entries so that the filter looks for traffic on specific VLANs. You can insert an ACE Ethernet VLAN ID only for ACL VLAN types.
- The ACL exists.
- The ACE exists.
- Click Advanced Filters (ACE/ACLs).
- Click the ACL tab.
- Select the appropriate ACL.
- Click ACE.
- Select the appropriate ACE.
- Click Eth.
- Click the Vlan Id tab.
- Click Insert.
- Specify the operation type.
- Enter the VLAN ID or select from a list.
- Click Insert.
VLAN ID field descriptions
Use the data in the following table to use the Vlan Id tab.
| Name | Description |
| AclId | Specifies the ACL ID. |
| AceId | Specifies the ACE ID. |
| Oper | The eq parameter specifies an operator for a field match condition: equal to. |
| VlanId | Specifies the VLAN ID on which to perform a match. |
| OperMask | Specifies the mask value for a VLAN attribute. |
