Configure ACE IP destination address entries to have the filter look for specific destination IP addresses.
- The ACL exists.
- The ACE exists.
- Click Advanced Filters (ACE/ACLs).
- Click the ACL tab.
- Select the appropriate ACL.
- Click ACE.
- Select the appropriate ACE.
- Click IP.
- Click the Destination Address tab.
- Click Insert.
- Specify the operation type.
- In the IPAddr box, enter the destination IP address.
- Click Insert.
Destination Address field descriptions
Use the data in the following table to use the Destination Address tab.
| Name | Description |
| AclId | Specifies the ACL ID. |
| AceId | Specifies the ACE ID. |
| Oper | The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits. |
| IPAddr | Specifies the destination IP address. |
| OperMask | Specifies the mask value for the destination IP address. |
