This procedure only applies to the VSP 7400 Series.
Perform this procedure to view the remote I-SID forwarding database (FDB) on the switch.
To view the T-UNI I-SID FDB entries filtered on a port that is part of an MLT, you must mention the MLT ID in the option for the port.
- Select ISID Remote.
- Optional: Select the Filter button to filter the rows on basis of specific criteria.
FDB Field Descriptions
Use data in the following table to use the FDB tab.
| Name | Description |
| IsidId | Specifies the service interface identifier (I-SID). |
| Address | Specifies the MAC address of the port assigned to the specific I-SID or C-MAC learned on the particular I-SID. |
| Status | Specifies the learning status of the associated MAC. |
| Port | Specifies the port on which the MAC is learned for the specific I-SID. |
| PortType | Specifies if the MAC address is learned locally or on an NNI port from a remote destination. |
| RemoteMacDestAddr | Specifies the virtual BMAC address or system-ID of the remote destination. |
| RemoteMacBVlanId | Specifies the B-VLAN ID on which the remote destination was discovered. |
| RemoteMacDestSysName | Specifies the remote destination system name. |
| Cvid | Specifies the customer VLAN ID of the associated Switched UNI port. |
