If FA discovery fails, use this procedure to display FA statistics to determine if FA discovery TLVs were processed. You can also view the FA assignment statistics to determine the number of FA assignments that were accepted or rejected by the FA Server.
You can view the statistics at either the global level or at the port (interface) level.
Viewing FA discovery and assignment statistics:
Switch:1>en
Switch:1#show fa statistics
                            Fabric Attach STATISTICS
Port      DiscElem   DiscElem   DiscElem   DiscAuth
          Received   Expired    Deleted    Failed
1/1       3057       0          1          0
1/2       2000       0          1          0
                      Fabric Attach ASSIGNMENTS STATISTICS
Port      Asgn       Asgn       Asgn       Asgn       Asgn       AsgnAuth
          Received   Accepted   Rejected   Expired    Deleted    Failed
1/1       3149       3          1          3          0          0
1/2       1500       0          1          2          0          0
View a summary of the FA discovery and assignment statistics:
Switch:1#show fa statistics summary
                            Fabric Attach STATISTICS SUMMARY
1/1       3057       0          1          0
1/2       2000       0          1          0
                      Fabric Attach ASSIGNMENTS STATISTICS SUMMARY
1/1       3149       3          1          3          0          0
1/2       1500       0          1          2          0          0
Viewing FA statistics on a specific port (port 1/1):
Switch:1>en
Switch:1#show fa statistics 1/1
1/1       3057       0          1          0
1/1       3149       3          1          3          0          0
Optionally, clear FA statistics and verify that the statistics are cleared.
Switch:1#clear fa statistics
1/1       0          0          0          0
1/2       0          0          0          0
1/1       0          0          0          0          0          0
1/2       0          0          0          0          0          0
The following table defines parameters for the show fa statistics command.
| Variable | Value |
| summary | Displays a summary of Fabric Attach element discovery and assignment statistics at the global level. |
| {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} | Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
