Use this procedure to display IP Multicast over Fabric Connect summary information.
Display IP Multicast over Fabric Connect global configuration information:
Switch:1>enable
Switch:1#show isis spbm multicast
                             multicast : enable
                     fwd-cache-timeout(seconds) : 210
Switch:1#show isis spb-mcast-summary
                            SPB multicast - Summary
SCOPE    SOURCE           GROUP            DATA          LSP  HOST
I-SID    ADDRESS          ADDRESS          I-SID   BVID  FRAG NAME
GRT      192.0.2.102     233.252.0.1        16000001  63  0x0  DIST5A
                        Switch:1>show ip mroute route
                          Mroute Route - GlobalRouter
GROUP           SOURCE          SRCMASK         UPSTREAM_NBR    IF     EXPIR  PROT
233.252.0.1       0.0.0.0         0.0.0.0         0.0.0.0        V3       30 spb-access
233.252.0.1       192.0.2.102     255.255.255.0   0.0.0.0        -        0  spb-network
233.252.0.2       0.0.0.0         0.0.0.0         0.0.0.0        V2      30  pimsm
225.1.1.1         198.51.100.99   255.255.255.0   0.0.0.0        V3      173 spb-pim-gw
Total 4
The following table defines parameters for the show isis spb-mcast-summary command.
| Variable | Value |
| count | Displays the total number of SPB multicast entries. |
| host-name WORD<0–255> | Displays the IP Multicast over Fabric Connect summary information for a specific host-name. |
| lspid <xxx.xxx.xxx.xx-xx> | Displays the IP Multicast over Fabric Connect summary information for the specified LSP ID that you enter in xxx.xxx.xxx.xx-xx — 8 byte format. |
The following table defines parameters for the show ip mroute route command.
| Variable | Value |
| vrf WORD<1–32> | Specifies a VRF. |
| vrfids WORD<0–255> | Specifies the VRF ID |
