Display the IP mroute Routes
Use the following procedure to display multicast routes ingressing on either SPB-PIM Gateway interfaces or SPB multicast interfaces.
The UPSTREAM_NBR field is populated only if the stream was learned across a spb-pim-gw interface, and the upstream neighbor is the PIM neighbor IP address toward the source. The PROT field equals spb-pim-gw when the stream‘s source is learned on a VLAN configured for protocol spb-pim-gw. If the stream's source is learned on a VLAN configured for spb-multicast, the PROT field equals spb.
Switch:1>show ip mroute route
                          Mroute Route - GlobalRouter
GROUP           SOURCE          SRCMASK         UPSTREAM_NBR    IF     EXPIR  PROT
233.252.0.1       0.0.0.0         0.0.0.0         0.0.0.0        V3       30 spb-access
233.252.0.1       192.0.2.102     255.255.255.0   0.0.0.0        -        0  spb-network
233.252.0.2       0.0.0.0         0.0.0.0         0.0.0.0        V2      30  pimsm
225.1.1.1         198.51.100.99   255.255.255.0   0.0.0.0        V3      173 spb-pim-gw
Total 4
Variable definitions
The following table defines parameters for the show ip mroute route command.
| Variable | Value |
| vrf WORD<1-32> | Displays the multicast mroute information for a specific VRF name. |
| vrfids WORD<0-512> | Displays the multicast mroute information for a range of VRF IDs. Note:
                                     Enter a single VRF ID or multiple VRF IDs separated by ‘,‘ or enter a range of VRF IDs ‘x-y‘. |
