Configure route advertisement in IPv6 on the management port for neighbor discovery (ND).
This procedure supports Layer 2 or Layer 3 route advertisement on VSP 8600 Series only.
Switch:1(config-if)#ipv6 nd dad-ns 2 Switch:1(config-if)#ipv6 nd hop-limit 2
Switch:1#show ipv6 nd interface mgmtethernet mgmt
                                             Mgmt Ipv6 Nd
IFID MGMT-IF RTR-ADV MAX-INT MIN-INT LIFETIME MANAG OTHER DAD-NS MTU HOP REACHABLE RETRANSMIT
                                             FLAG  CONF             LIMIT  TIME      TIME
64   mgmt   False   600     200      0      False  False 2      0(d) 2(s)   0(d)    0(d)
Note:  (s)= Set, (d)= Default, (i)= inherit.
1 out of 5 Total Num of IPv6 ND Entries displayed.
Variable definitions
Use the data in the following table to use the ipv6 nd command.
| Variable | Value |
| dad-ns <0–600> | Specifies the number of neighbor solicitation messages for duplicate address detection (DAD). A value of 0 disables the DAD process on this interface. A value of 1 sends one advertisement without retransmissions. The default is 1. |
| hop-limit <0–255> | Specifies the current hop limit field sent in router advertisements from this interface. The value must be the current diameter of the Internet. A value of zero indicates that the advertisement does not specify a hop-limit value. The default is 64. |
