Use this procedure to enable transmission of dot3 MAC/PHY configuration/status Link Layer Discovery Protocol (LLDP) TLV.
Enable LLDP TLVs for transmission on a specific port:
Switch:1>enable Switch:1#config Configuring from terminal or network [terminal]? t Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitethernet 1/2 Switch:1(config-if)#lldp tx-tlv dot3 mac-phy-config-status
Switch:1(config-if)#show lldp tx-tlv dot3
                              LLDP port dot3 tlvs
Port       MAC Physical
           Config Status
1/1        disabled
1/2        enabled
1/3        enabled
1/4        disabled
1/5        disabled
The following table defines parameters for the lldp tx-tlv dot3 command.
| Variable | Value |
| mac-phy-config-status | Specifies the status of the MAC Physical Config Status TLV. The default is disabled. |
