Perform this procedure to enable Energy Saver or EEE on one or more ports.
- On the Device Physical View tab, select one or more ports.
- Select General.
- Select the Energy Saver tab.
                Enable either Energy Saver or EEE:
                        To enable Energy Saver, select EnergySaverEnabled.
                        To enable EEE, select EnergySaverEEEEnable.
- Select Apply.
Energy Saver Field Descriptions
Use the data in the following table to use the Energy Saver tab.
| Name | Description |
| Port | Specifies the port number. |
| EnergySaverEnabled | Configures whether Energy Saver is enabled on the specific port. |
| EnergySavedPoeStatus | Specifies the Energy Saver PoE status for the specific port. |
| EnergySaverEEEEnable | Configures whether EEE is enabled on the specific port. |
