Use this procedure to view the LLDP port information.
- Click LLDP.
- Click the Port tab.
- View the administrative status of the port in the AdminStatus field. To modify, double-click on a cell and select a value from the drop-down list.
- View whether the port is enabled for notifications in the NotificationEnable field. To modify, double-click on a cell and select a value from the drop-down list.
- View the set of TLVs whose transmission using LLDP is always allowed by network management in the TLVsTxEnable field.
- Optional: Modify the TLVs as
follows:
- To enable a TLV, select the appropriate check box, and click Ok. You can select more than one check box.
- To enable all TLVs, click Select All, and click Ok.
- To disable all TLVs, click Disable All, and click Ok.
- View the CDP administrative status in the CdpAdminState field. To modify, double-click on a cell and select a value from the drop-down list.
- Click Apply to save any configuration changes.
- Click Refresh to verify the configuration.
Port Field Descriptions
Use the data in the following table to use the Port tab.
| Name | Description |
| PortNum | Specifies the port number. This is a read-only cell. |
| AdminStatus | Specifies the administrative status of the port. The options are:
 The default is disabled. |
| NotificationEnable | Specifies whether the port is enabled or disabled for notifications.
 The default is false. |
| TLVsTxEnable | Specifies the set of TLVs whose transmission using LLDP is always allowed by network management. The following list describes the TLV types:
 The default is an empty set of TLVs. |
| CdpAdminState | Specifies the CDP administrative status of the port. Configure this field to true to enable the Industry Standard Discovery Protocol (ISDP) on a port. ISDP is CDP-compatible.
 The default is false. If CDP is enabled, the interface accepts only CDP packets. Similarly, if CDP is disabled but LLDP is enabled, the interface accepts only LLDP packets. To switch a port from CDP mode to LLDP mode, the LLDP status on that port must be txAndRx. |
| CapSupported(med) | Specifies the LLDP-MED capabilities supported. The default is enabled. |
