This procedure does not apply to VSP 8600 Series.
Use this task to view UDP statistics for a Segmented Management Instance.
- Select Mgmt Instance.
- Select Stats.
- Select the IP/IPv6 UDP tab.
IP/IPv6 UDP Field Descriptions
Use the data in the following table to use the IP/IPv6 UDP tab.
| Name | Description |
| IPVersion | Shows the IP address version as ipv4 or ipv6. |
| InDatagrams | Shows the input datagram statistics. |
| NoPorts | Shows the number of ports statistics. |
| InErrors | Shows the input errors statistics. |
| OutDatagrams | Shows the output datagram statistics. |
| IgnoredMulti | Show the ignored multiport statistics. |
| RcvbufErrors | Shows the received buffer errors statistics. |
| SndbufErrors | Shows the send buffer errors statistics. |
| InCsumErrors | Shows the input checksum errors statistics. |
| Clear | Specifies to clear the statistics. Default is false. |
