Configure mesh groups to reduce SA flooding. A mesh group does not forward SA messages to other
            group members. The originator, which is also a mesh group member, forwards SA messages
            to all group members. Create MSDP mesh groups from a group of meshed MSDP speakers from
            a domain.
The MSDP router does not belong to any mesh group by default.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip msdp mesh-group helloworld 21.0.0.2
Variable definitions
The following table defines parameters for the ip msdp mesh-group command.
| Variable | Value |
| WORD<1-64> | Specifies the mesh group name. |
| {A.B.C.D} | Specifies the MSDP peer IP address. |
