To operate properly, Fabric Attach (FA) must be configured properly at both the global and interface level on the switch. Use this procedure to verify FA configuration.
enable
show fa
show fa agent
show fa interface
To view FA configuration on all ports, enter:
show fa interface port
To view FA configuration on a specific port, enter:
show fa interface port [{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}]
To view FA configuration on all MLTs, enter:
show fa interface mlt
To view FA configuration on a specific MLT, enter:
show fa interface mlt [<1-512>]
To view FA interface configuration based on the authentication status, enter:
show fa interface [enabled-auth] [disabled-auth]
Verify that FA is configured globally.
Switch:1>show fa
                          Fabric Attach Configuration
                            FA Service : enabled
                       FA Element Type : server
                 FA Assignment Timeout : 240
                  FA Discovery Timeout : 240
                     FA Provision Mode : spbm
Verify FA configuration at the interface (port or MLT) level, on all interfaces.
In the following example output, note that:
FA is enabled on interfaces 2/10, 4/11 and Mlt2.
Both FA and message authentication are disabled on port 4/6.
Both FA and message authentication are enabled on port 4/11.
Switch:1#show fa interface
                            Fabric Attach Interfaces
INTERFACE    SERVER   MGMT     MGMT     MSG AUTH MSG AUTH   ORIGIN
             STATUS   ISID     CVID     STATUS   KEY
Port2/10     enabled  0        0        disabled ****
Port4/6      disabled 0        0        disabled ****
Port4/11     enabled  0        0        enabled  ****
Mlt2         enabled  0        0        disabled ****
 4 out of 4 Total Num of fabric attach interfaces displayed
Verify FA configuration on a specific port, for example, on port 2/10.
Switch:1#show fa interface port 2/10
 1 out of 1 Total Num of fabric attach interfaces displayed
Verify FA configuration on an MLT, for example, on Mlt2.
Switch:1#show fa interface mlt 2
View the FA interfaces that have authentication enabled:
Switch:1#show fa interface enabled-auth
View the FA interfaces that have authentication disabled:
Switch:1#show fa interface disabled-auth
3 out of 3 Total Num of fabric attach interfaces displayed
