After you have configured the SPBM infrastructure, you can enable SPBM Layer 3 VSN to advertise IPv4 routes across the SPBM network from one VRF to another using the following procedure.
SPBM Layer 3 VSN uses IS-IS to exchange the routing information for each VRF. In the VRF, just like in the Global Router (VRF 0), the routes are not redistributed into IS-IS automatically. To advertise the VRF routes, you must explicitly redistribute one of the following protocols into IS-IS: direct, static, RIP, OSPF, or BGP. Routing between VRFs is also possible by using redistribution policies and injecting routes from the other protocols.
                                             You must configure the required SPBM IS-IS infrastructure.
                                             You must configure a VRF on the switch. For more information, see VRF Lite configuration using the CLI.
                                             You must create the Customer VLANs and add slots/ports.
Create the IPv4 VPN instance:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router vrf green
Switch:1(config)#ipvpn
Switch:1(config)#i-sid 109
Switch:1(config)#ipvpn enable
Switch:1(config)#show ip ipvpn
                                        IPv4 IPVPN
VRF Name            VRF ID   IPv4 IPVPN   IPv6 IPVPN   I-SID        I-SID Name
green               1        enabled      disabled     109          ExtremeServer1
1 out of 1 Total IPv4 L3 VSN, 1 active IPv4 and 0 active IPv6 displayed.
Switch:1(config)#isis redistribute ospf
Switch:1(config)#isis redistribute ospf enable
Switch:1(config)#end
Switch:1(config)#isis apply redistribute ospf vrf vrfred
Switch:1(config)#show ip isis redistribute vrf vrfred
                        ISIS Redistribute List - VRF vrfred
SOURCE MET MTYPE      SUBNET   ENABLE LEVEL  RPOLICY
LOC    1   internal   allow    FALSE  l1
The following table defines parameters for the show ip ipvpn command.
| Variable | Value |
| vrf WORD<1–16> | Specifies the VRF name. |
| vrfids WORD<0–512> | Specifies the VRF ID. |
The following table defines parameters for the i-sid command.
| Variable | Value |
| <0–16777215> | Assigns an I-SID to the VRF being configured. Use the no or default option to remove the I-SID to VRF allocation for this VRF. |
The following table defines parameters for the isis redistribute command.
| Variable | Value |
| {direct | bgp | ospf | rip | static} | Specifies the protocol. |
| enable | Enables the redistribution of the specified protocol into the SPBM network. The default is disabled. Use the no or default options to disable the redistribution. |
| metric <0–65535> | Configures the metric (cost) to apply to redistributed routes. The default is 1. |
| metric-type {external|internal} | Configures the type of route to import into the protocol. The default is internal. |
| route-map WORD<0–64> | Configures the route policy to apply to redistributed routes. Specifies a name. |
| subnets {allow|suppress} | Indicates whether the subnets are advertised individually or aggregated to their classful subnet. Choose suppress to advertise subnets aggregated to their classful subnet. Choose allow to advertise the subnets individually with the learned or configured mask of the subnet. The default is allow. |
The following table defines parameters for the isis apply redistribute command.
| Variable | Value |
| vrf WORD<1–16> | Applies IS-IS redistribute for a particular VRF. Specifies the VRF name. |
