Perform this procedure to view all the configured I-SIDs including their types, ports, and MLTs.
View all configured I-SIDs (both CVLAN and T-UNI). View also the I-SID types and the ports or MLTs that are assigned to each I-SID.
View all configured I-SIDs.
Switch:1(config)#show i-sid
                                                       Isid Info
ISID       ISID               PORT         MLT           ORIGIN                    ISID
ID         TYPE      VLANID   INTERFACES   INTERFACES                              NAME
15999999   ELAN      4048     -            -             C  ---  -  ---  -  -      Onboarding I-SID
16777001   ELAN      N/A      -            -             C  ---  -  ---  -  -      FAN-ISID
c: customer vid    u: untagged-traffic
All 2 out of 2 Total Num of i-sids displayed
ORIGIN Legend:
C: manually configured; D: discovered by FA or EPT
M: FA management; E: discovered by EAP; A: auto-sense; R: multi-area redist
l: discover by local switch  r: discover by remote VIST switch
View T-UNI (ELAN Transparent) I-SIDs.
Switch:1 (config)#show i-sid elan-transparent
                                   Isid Info
ISID       ISID                    PORT           MLT           ISID
2          ELAN_TR    N/A            -            -             ExtremeServer2
25         ELAN_TR    N/A          1/2-1/8,8/11   25            ExtremeServer4
All 1 out of 1 Total Num of elan-tp i-sids displayed
View MLT or port information for a particular T-UNI I-SID.
Switch:1(config)#show i-sid 111
                                   Isid Info
111    ELAN_TR    N/A       1/2-1/8,8/11  111         CONFIG      ISID-111
View all IS-IS SPBM I-SID information:
Switch# show isis spbm i-sid all
        SPBM ISID INFO
ISID      SOURCE NAME    VLAN   SYSID                TYPE         HOST_NAME            ISID NAME        AREA       AREA NAME
101001    1.11.16        4051   0200.10ff.fff0       discover     area-0.00.10         ISID-101001      HOME       area-0.00.20
101003    1.11.16        4051   0200.10ff.fff0       discover     area-0.00.10         ISID-101003      HOME       area-0.00.20
101005    1.11.16        4051   0200.10ff.fff0       discover     area-0.00.10         ISID-101005      HOME       area-0.00.20
101007    1.11.16        4051   0200.10ff.fff0       discover     area-0.00.10         ISID-101007      HOME       area-0.00.20
101009    1.11.16        4051   0200.10ff.fff0       discover     area-0.00.10         ISID-101009      HOME       area-0.00.20
101011    1.11.16        4051   0200.10ff.fff0       discover     area-0.00.10         ISID-101011      HOME       area-0.00.20
 Total number of SPBM ISID entries configed: 0
 Total number of SPBM ISID entries discovered: 6
 Total number of SPBM ISID entries: 6
View all IS-IS SPBM I-SID information by I-SID ID:
Switch:1#show isis spbm i-sid all id 300
                                 SPBM ISID INFO
300   7.15.16       20    a425.1b51.9484    config    Switch1    ISID-300    HOME   area-0.00.20
300   4.01.18       10    b4a9.5a2a.d065    discover  Switch2    ISID-300    HOME   area-0.00.20
 Total number of SPBM ISID entries configured: 1
 Total number of SPBM ISID entries discovered: 1
 Total number of SPBM ISID entries: 2
When SPB is enabled, I-SID IDs 16777216 and greater are reserved for internal I-SID and SPB multicast.
The following table defines parameters for the show i-sid command.
| Variable | Value |
| <1–16777215> | Specifies the service interface identifier (I-SID). |
| elan-transparent | Displays only all the Elan-Transparent (T-UNI based) I-SIDs. |
The following table defines parameters for the show isis spbm i-sid command.
| Variable | Value |
| {all|config|discover} |
| vlan <2-4059> | Displays I-SID information for the specified SPBM VLAN. |
| id <1–16777215> | Displays I-SID information for the specified I-SID. |
| nick-name <x.xx.xx> | Displays I-SID information for the specified nickname. |
