Use a port-based policer to bandwidth-limit ingress traffic. The
system drops or re-marks violating traffic.
- In the Device Physical
View tab, select a port.
                In the navigation tree, expand
                Select General.
                Select the Interface
                    tab.
                From IngressRatePeak,
                    type the value for the peak rate in Kbps.
                    The peak rate must be greater than or equal to the service rate.
                From IngressRateSvc,
                    type the value for the service rate in Kbps.
                Select Apply.
