Use the following procedure to configure the SPBM interface parameters.
- Select SPBM.
- Select the Interfaces SPBM tab.
- Configure the SPBM interface parameters.
- Select Apply.
Interfaces SPBM Field Descriptions
Use the data in the following table to use the Interfaces SPBM tab.
| Name | Description |
| Index | Specifies an Index value for the SPBM interface. |
| SpbmId | Specifies the SPBM ID. |
| State | Specifies whether the SPBM interface is enabled or disabled. |
| Type | Configures the SPBM instance interface-type on the IS-IS interface located on the specified port or MLT: ptpt or bcast. Only the point-to-point (ptpt) interface type is supported. |
| L1Metric | Configures the IS-IS Interface level 1 metric on the specified port or MLT. The default value is 10. |
| Origin Note:
                                     Exception: not supported on VSP 8600 Series or XA1400 Series. | Specifies the source of the SPBM instance configuration, either manually configured through CLI or EDM, or dynamically configured through Auto-sense. |
