View Traceroute Results
View traceroute results to view performance-related data.
Troubleshooting using ping and traceroute is not supported on EDM. For more information, see VOSS Release Notes. As an alternative, use CLI.
- From the navigation pane, expand .
- Click Ping/Trace Route.
- Click the Trace Route Control tab.
- Select a traceroute entry.
- Click Trace Route Result.
Trace Route Result Field Descriptions
Use the data in the following table to use the Trace Route Result tab.
| Name | Description |
| OwnerIndex | Specifies the index of the owner. |
| TestName | Specifies the name of the test. |
| OperStatus | Specifies the operational status of the test. The default is disabled. |
| CurHopCount | Specifies the current count of hops. |
| CurProbeCount | Specifies the current count of probes. |
| IpTgtAddressType | Specifies the IP target address type |
| IpTgtAddr | Specifies the IP target address. |
| TestAttempts | Specifies the number of test attempts. |
| TestSuccesses | Specifies the number of successful test attempts. |
| LastGoodPath | Specifies the date and time when the last response is received for a probe. |
