Clear the SA cache to clear the SA entries the router learns from all the peers or a specific peer.
- Click MSDP.
- Click the SA-Cache tab.
- Click Clear SA-Cache.
SA-Cache field descriptions
Use the data in the following table to use the SA-Cache tab.
| Name | Description |
| GroupAddr | Shows the group IP address of the SA cache entry. |
| SourceAddr | Shows the source IP address of the SA cache entry. |
| OriginRP | Shows the RP address of the SA cache entry. |
| PeerLearnedFrom | Shows the peer from which this SA cache entry was accepted. |
| RPFPeer | Shows the peer from which an SA message corresponding to the cache entry is accepted. |
| InSAs | Discontinuities in the value of this counter can occur at reinitialization of the management system. |
| InDataPackets | Shows the number of MSDP encapsulated data packets received that are relevant to this cache entry. |
| UpTime | Shows the time since this entry was first placed in the SA cache. |
| ExpiryTime | Shows the time remaining before this entry expires from the SA cache. |
