Change the VRF instance as required to configure a Circuitless IPv6 interface on a specific VRF instance.
You can use a circuitless IPv6 (CLIPv6) interface to provide uninterrupted connectivity to your system.
- In the navigation pane, expand Configuration > IPv6.
- Click IPv6.
- Click the Circuitless IP tab.
- Click Insert.
- In the Interface field, assign a CLIP interface number.
- Type the IPv6 address and prefix length.
Circuitless IPv6 Field Descriptions
Use the data in the following table to use the Circuitless IPv6 tab.
| Name | Description |
| Interface | Specifies the interface to which this entry applies. |
| Addr | Specifies the IPv6 address to which this entry applies. |
| AddrLen | Specifies the prefix length value for this address. You cannot change the address length after you create it. You must provide this value to create an entry in this table. |
| Name Note:
                                     This field does not apply to all hardware platforms. | Specifies the name assigned to the IPv6 CLIP address. |
