You can disable the SSH client functionality on the switch. By default, the SSH client functionality is enabled.
In order to enable the SSH client functionality, SSH must be enabled globally.
enable
configure terminal
no ssh client <enable>
ssh client <enable>
default ssh client <enable>
You must enable SSH globally before the SSH client functionality can be re-enabled.
Display the general SSH settings::
Switch:1(config)# show ssh global
Total Active Sessions  :  0
        version                : v2only
        port                   : 22
        max-sessions           : 4
        timeout                : 60
        action rsa-host key    : rsa-hostkeysize 2048
        action dsa-host key    : dsa-hostkeysize 1024
        rsa-auth               : true
        dsa-auth               : true
        pass-auth              : true
        keyboard-interactive-auth : false
        sftp enable            : true
        enable                 : true
        client enable          : true
Disable SSH client functionality:
Switch:1(config)# no ssh client
        version                : v2only
        port                   : 22
        max-sessions           : 4
        timeout                : 60
        rsa-auth               : true
        dsa-auth               : true
        pass-auth              : true
        sftp enable            : true
        enable                 : true
        client enable          : false
