Display detailed statistics for specific ports to manage network performance.
Slot and port information can differ depending on hardware platform.
View statistics for various ports:
Switch:1>enable
Switch:1#show interfaces gigabitethernet statistics verbose
Please widen the terminal for optimal viewing of data.
                      Port Stats Interface Extended
PORT_NUM IN_UNICST  OUT_UNICST IN_MULTICST OUT_MULTICST IN_BRDCST OUT_BRDCST IN_LSM OUT_LSM
2/1      0          0          0            0            0          0         0     0
2/2      0          0          0            0            0          0         0     0
2/3      0          0          0            0            0          0         0     0
2/4      0          0          0            0            0          0         0     0
2/5      0          0          0            0            0          0         0     0
2/6      0          0          0            0            0          0         0     0
3/1      0          0          0            0            0          0         0     0
3/2      0          0          0            0            0          0         0     0
3/3      0          0          8702         34805        0          0         0     0
3/4      0          0          0            0            0          0         0     0
3/5      0          0          0            0            0          0         0     0
3/6      0          0          0            0            0          0         0     0
3/7      0          0          0            0            0          0         0     0
3/8      0          0          0            0            0          0         0     0
3/9      0          0          0            0            0          0         0     0
--More-- (q = quit)
Use the data in the following table to use the show interfaces GigabitEthernet statistics verbose command.
| Variable | Value |
| {slot/port[/sub-port][-slot/port[/sub-port]][,...]} | Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
