Use the following procedure to create and configure an IKEv2 profile.
- Click IKE.
- Click the V2 Profile tab.
- Click Insert.
- In the Name field, type a profile name.
- Complete the remaining optional configuration to customize the policy.
- Click Insert.
V2 Profile field descriptions
Use the data in the following table to use the tab.
| Name | Description |
| Name | Specifies the IKE v2 profile name. |
| HashAlgorithm | Specifies the type of hash algorithm that can be used during IKE version 2 SA version 2 negotiation. The default value is sha256. |
| EncryptionAlgorithm | Specifies the encryption algorithms that can be used during IKE version 2 SA version 2 negotiation. The default value is aesCbc. |
| EncryptKeyLen | Specifies the type of encryption algorithm. The default value is keylen–256. |
| DHGroup | Specifies the Diffie-Hellman (DH) group. DH groups categorize the key used in the key exchange process, by its strength. The key from a higher group number is more secure. The default value is modp2048. |
| ExchangeMode | Specifies the IKE v2 profile negotiation mode. The default value is main. |
| LifetimeSeconds | Specifies the lifetime value in seconds. The lifetime ensures that the peers renegotiate the SAs just before the expiry of the lifetime value, to ensure that Security Associations are not compromised. The default value is 86400 seconds. |
| IntegrityAlgorithm | Specifies the type of integrity algorithm. |
