This procedure does not apply to VSP 8600 Series.
Use this task to view IPv6 operational routes.
- Select Mgmt Instance.
- Select Mgmt.
- Select the Ipv6Route tab.
Ipv6Route Field Descriptions
Use the data in the following table to use the Ipv6Route tab.
| Name | Description |
| DestAddr | Shows the destination address of the route entry. |
| PrefixLen | Shows the destination prefix length of the route entry. |
| Metric | Shows the metric, or cost, assigned to the route entry. If multiple entries exist to the same destination, the metric determines which route is used. Routes with a type of LOCAL have a metric equal to 256. |
| Instance | Shows the Management Instance ID. |
| NextHop | Shows the next hop for the route entry. |
| IntfName | Shows the Management Instance interface name for the route entry. |
| Type | Shows the type of route entry. |
