This procedure only applies to VSP 4900 Series and VSP 7400 Series.
Perform this procedure to limit the number of multicast streams to protect a Central Processing Unit (CPU) from multicast data packet bursts generated by malicious applications, such as viruses that cause the CPU to reach 100 percent utilization, or that prevent the CPU from processing protocol packets or management requests. If more than a certain number of multicast streams ingress to a CPU through a port during a sampling interval, the port shuts down until you take appropriate action.
- Select the Extreme Integrated Application Hosting (IAH) port you want to configure.
- Select the Mroute Stream Limit tab.
- Select StreamLimitEnable.
- Configure other fields as required.
- Select Apply.
Mroute Stream Limit Field Descriptions
Use data in the following table to configure the Mroute Stream Limit tab.
| Name | Description |
| StreamLimitEnable | Enables or disables mroute stream limit on the Extreme Integrated Application Hosting (IAH) port. The default is disabled. |
| StreamLimit | Specifies the maximum number of multicast streams allowed to enter the CPU through the IAH port. The default value is 1984. |
| StreamTimerCheck | Specifies the sampling period, in seconds, to check the number of multicast streams that enter the CPU through the IAH port. The default is 10 seconds. |
