Use the following procedure to install the Root CA certificate obtained offline.
This procedure applies to VSP 8600 Series only.
- Select System Log.
- Select Root Certificate Table tab.
- Select Insert.
- In the Filename field, enter the filename obtained offline from the CA.
- In the Action field, select the action.
- Select Insert.
Root Certificate Table field description
Use the data in the following table to use the tab.
| Name | Description |
| Filename | Specifies the certificate filename obtained offline from the Root Certificate Authority. |
| Action | Specifies the action to be performed on Root CA.
 The system displays the Conversion Fail if the execution of the action fails. |
