					You must enable IPv6 Shortcuts.
					You must configure the required SPBM IS-IS infrastructure.
					You must configure a VRF instance on the switch. For more information, see VRF Lite configuration using the CLI.
After you have configured the SPBM infrastructure, you can enable SPBM Layer 3 VSN to advertise IPv6 routes across the SPBM network using the following procedure.
Create the IPv6 VPN instance:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router vrf vrfred
Switch:1(router-vrf)#ipv6 ipvpn
Switch:1(router-vrf)#i-sid 100
Switch:1(router-vrf)#ipv6 ipvpn enable
Switch:1(router-vrf)#show ipv6 ipvpn
                                        IPv6 IPVPN
VRF Name            VRF ID   IPv6 IPVPN   IPv4 IPVPN   I-SID        I-SID Name
vrfred              2        enabled      disabled     100          ISID-100
1 out of 1 Total IPv6 L3 VSN, 1 active IPv6 and 0 active IPv4 displayed.
Switch:1(router-vrf)#ipv6 isis redistribute direct enable
Switch:1(router-vrf)#ipv6 ospf redistribute isis enable
Switch:1(router-vrf)#ipv6 ospf apply redistribute isis vrf vrfred
Switch:1(router-vrf)#show ipv6 route vrfred
                                       IPv6 Routing Table Information - VRF vrfred
Destination Address/PrefixLen      NEXT HOP              VID/BID/TID  PROTO   COST  AGE   TYPE     PREF
55:0:0:0:0:0:0:0/64                Switch                 V-2         ISIS     10    0      B        7
1 out of 1 Total Num of Route Entries displayed.
TYPE Legend:
A=Alternative Route, B=Best Route, E=Ecmp Route
The following table defines parameters for the ipv6 ipvpn command.
| Variable | Value |
| enable | Enables IPv6 IPVPN. The default is disabled. |
The following table defines parameters for the show ipv6 ipvpn command.
| Variable | Value |
| vrf WORD<1–16> | Specifies the VRF name. |
| vrfids WORD<0–512> | Specifies the VRF ID. |
The following table defines parameters for the i-sid command.
| Variable | Value |
| <0–16777215> | Assigns an I-SID to the VRF being configured. |
The following table defines parameters for the isis redistribute command.
| Variable | Value |
| {bgp | direct | ospf | static} | Specifies the protocol. |
| enable | Enables the redistribution of the specified protocol into the SPBM network. The default is disabled. |
