![Note](images/note.png)
This procedure only applies to the VSP 7400 Series.
Perform this procedure to view the remote Intermediate-System-to-Intermediate-System (IS-IS) and SPBM summary.
- Select IS-IS Remote.
- Select the Protocol Summary tab.
Protocol Summary Field Descriptions
Use data in the following table to use the Protocol Summary tab.
Name |
Description |
AdminState |
Indicates the global status of remote IS-IS on the switch. |
SystemId |
Indicates the remote IS-IS system ID of the switch. |
NodeNickName |
Indicates the nickname for the remote SPBM instance globally. |
Circuit Index |
Indicates the identifier of the IS-IS circuit. This value is for SNMP indexing purposes only and does not have any relation to any protocol value. |
IfIndex |
Indicates the interface to which the circuit corresponds. |
AdminState |
Indicates the administrative state of the circuit.
OperState |
Indicates the operational state of the circuit.
Circuit Index |
Indicates the unique identifier of the remote IS-IS circuit. This value is for SNMP Indexing purposes only and does not have any relation to any protocol value. |
AdjIndex |
Indicates value identifying the IS-IS adjacency from all other such adjacencies on the circuit. The system dynamically assigns this value when it forms an adjacency. |
Interface |
Indicates the remote IS-IS interface. |
AdjState |
Indicates the state of the adjacency:
AdjNeighSysID |
Indicates the system ID of the neighboring IS-IS. |
AdjHostName |
Indicates the host name listed in the LSP, or the system name if the host name is not configured. |
