This procedure only applies to VSP 4450 Series.
View port routing statistics to manage network performance.
- In the Device Physical View, select a port.
- In the navigation tree, expand .
- Select Port.
- Select the Routing tab.
Routing Field Descriptions
Use the data in the following table to use the Routing tab.
| Name | Description |
| InUnicastFrames | The number of incoming unicast frames routed. |
| InMulticastFrames | The number of incoming multicast frames routed. |
| InDiscards | The number of frames discarded by the routing entity. |
| OutUnicastFrames | The number of outgoing unicast frames routed. |
| OutMulticastFrames | The number of outgoing multicast frames routed. |
