Use this procedure to display the MAC addresses that are learned or statically configured for a VLAN. In order to learn you have to be connected to another switch or host and receive some traffic.
The VSP 4450 Series does not display a log message when MAC learning maximum limit is reached.
View VLAN forwarding database information:
Switch:1> show vlan mac-address-entry
                                    Vlan Fdb
VLAN            MAC                           SMLT
ID   STATUS     ADDRESS            INTERFACE  REMOTE TUNNEL
1    learned    f8:15:47:e1:80:0c  Port-1/2   false  -
2    learned    32:20:d3:81:00:77  Port-1/9   false  -
4    learned    b4:a9:5a:2b:78:31  Port-2/1   false  -
3 out of 3 entries in all fdb(s) displayed.
 View where entries are learned. The TUNNEL column indicates where in the SPBM network an entry is learned.
Switch:1> show vlan mac-address-entry spbm-tunnel-as-mac
                                    Vlan Fdb
VLAN            MAC                           SMLT
Use the data in the following table to use optional parameters with the show vlan mac-address-entry command.
| Variable | Value |
| <1-4059> | Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1. |
| mac <0x00:0x00:0x00:0x00:0x00:0x00> | Specifies the MAC address. |
| port {slot/port[-slot/port][,...]} | Specifies the port or port list. |
| spbm-tunnel-as-mac | Displays where entries are learned. The TUNNEL column indicates where in the SPBM network an entry is learned. |
