This procedure only applies to VSP 4900 Series and VSP 7400 Series.
Perform this procedure to configure the rate limit of broadcast or multicast packets and determine the total bandwidth limit on the Extreme Integrated Application Hosting (IAH) port.
- Select the IAH port you want to configure.
- Select the Rate Limiting tab.
- In the AllowedRatePps column, enter a time duration for the specific Extreme Integrated Application Hosting port.
- In the Enable column, select true to enable rate limiting for the specific IAH port.
- Select Apply.
Rate Limiting Field Descriptions
| Name | Description |
| Index | Specifies the Extreme Integrated Application Hosting (IAH) port. |
| TrafficType | Shows the traffic type. The default is broadcast. |
| AllowedRatePps | Specifies the allowed traffic rate limit for the IAH port in packets per second (pps). |
| Enable | Enables or disables rate limiting for the specific IAH port. The default is false (disabled). |
