This procedure only applies to VSP 4900 Series and VSP 7400 Series.
Perform this procedure to enable Virtual Link Aggregation Control Protocol (VLACP) on an Extreme Integrated Application Hosting (IAH) port. VLACP periodically checks the end-to-end health of a point-to-point connection.
- In the navigation tree, expand .
- Select the IAH port you want to configure.
- Select the VLACP tab.
- Select AdminEnable.
- Configure the other parameters as required.
- Select Apply.
VLACP Field Descriptions
Use data in the following table to configure the VLACP tab.
| Name | Description |
| AdminEnable | Enables VLACP on the Extreme Integrated Application Hosting (IAH) port. The default is disabled. |
| OperEnable | Specifies the VLACP operational status for the IAH port. The default is false. |
| FastPeriodicTimer | Specifies the number of milliseconds between periodic transmissions using short timeouts. Set the same value for all LACP enabled IAH ports. The default value is 200. |
| SlowPeriodicTimer | Specifies the number of milliseconds between periodic transmissions using long timeouts. Set the same value for all LACP enabled IAH ports. The default value is 30000. |
| Timeout | Specifies the timeout control value. The default value is long. |
| TimeoutScale | Specifies the value used to calculate timeout duration from the periodic time for all VLACP enabled IAH ports. Timeout = PeriodicTime x TimeoutScale. The default value is 3. |
| EtherType | Specifies the VLACP protocol identification. The ID is in hexadecimal format. The default value is 0x8103. |
| EtherMacAddress | Specifies the multicast MAC address exclusively used for VLACPDUs. |
| PortState | Specifies the VLACP port state. |
