In releases prior to VOSS release 8.1.60, perform this procedure to identify a pre-existing VLAN or loopback management interface to migrate to the Segmented Management Instance after you upgrade. This action moves the IP interface from the routing stack to the management stack to use with management applications. In releases later than VOSS 8.1.60, you can perform this procedure to migrate a new routing VLAN with a new IP address or a new loopback IP address under a different VRF to the Segmented Management Instance. Alternatively, you can also use the convert command. For more information, see Change Management Instance Attributes.
Important
Choose a VLAN that does not have an IP interface on it. The upgrade process removes the IP configuration and network connectivity will be impacted.
Do not migrate interfaces used for routing purposes, for example, where you configure Layer 3 routing protocols.
This command does not apply to the OOB or mgmtEthernet interface. Releases that support this migration procedure automatically move the IP address on the mgmtEthernet interface from the routing stack to the Segmented Management Instance during the upgrade to this release.
enable
configure terminal
interface vlan <1–4059> or interface loopback <1–256>
migrate-to-mgmt
show mgmt migration
save config
Identify an IP address currently assigned to an inband VLAN to migrate to the Management VLAN. The example assumes you already identified a CLIP address. The VRF column in show mgmt migration indicates where the interface is being moved from.
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#interface vlan 20
Switch:1(config-if)#migrate-to-mgmt
Switch:1(config-if)#show mgmt migration
                                    Mgmt Migration Information
IFINDEX   DESCR      VRF            IPV4                 IPV6
1344      CLIP-1     GlobalRouter   192.0.2.102/32       10:0:0:0:0:0:0:1/128
2068      VLAN-20    GlobalRouter   198.51.100.6/24      20:0:0:0:0:0:0:1/64
2 out of 2 Total Num of mgmt migrate entries displayed
Switch:1(config-if)#save config
